TwinTurbo.NET: Nissan 300ZX forum - Don't unbolt the turbo from the manifold
awesom-o
on July 26, 2008 at 12:51 AM
Probably due to improper torquing procedure.
posted by Waggz
on July 26, 2008 at 12:33 AM
unbolt the test pipes or cats from the down pipes and pull the turbos/dp's with the heads.
White wheels are getting painted silver this winter.
head removal
spdrmn
00:01:31 07/26/08
Yes.
Waggz
00:11:13 07/26/08
Re: Yes.
spdrmn
00:24:58 07/26/08
Waggz
00:33:56 07/26/08
Don't unbolt the turbo from the manifold -
awesom-o
00:51:26 07/26/08
Is that easier?
Waggz
01:01:55 07/26/08
Re: Is that easier?
awesom-o
01:35:33 07/26/08
How tight of a fit?
Waggz
02:20:29 07/26/08
larger upgraded turbo's wont make much of a difference (n/m)
550HPTT
05:59:25 07/26/08
^^^^^ He's right, it's basically the same
awesom-o
07:23:18 07/26/08
that's good info. thanks (n/m)
won4all
18:42:46 07/26/08
turning those head bolts is a BITCH (n/m)
amp300zx
00:49:52 07/26/08
If you're asking it's probably way over your head.
apudapus
04:13:07 07/26/08
are you sure your head gasket is leaking?
aliaZ
07:21:23 07/26/08
true... true (n/m)
550HPTT
09:44:39 07/26/08
Re: are you sure your head gasket is leaking?
spdrmn
10:45:34 07/26/08
Re: head removal
spdrmn
14:10:41 07/26/08
